HELP with BCM!
Old Dec 24, 2010 | 12:18 PM
Hurricane D's Avatar
Hurricane D is on a distinguished road
Default HELP with BCM!
Working on a 2001 2wd with the 4.3l V6. I can't seem to find where the BCM ground wire is connected to on the frame. I have been looking for pics or diagrams, but nothing. Any info would help. Thanks.
Old Dec 24, 2010 | 12:27 PM
stlwaco's Avatar
stlwaco is on a distinguished road
I looked in alldata and I can't find a diagram. All I could find was connector views. Only one connector has grounds. If you think you have a ground issue, you could always try to ground it yourself. Below a connector view with a description of each pin on that connector.
Brown Connector
Old Dec 24, 2010 | 12:32 PM
There are two grounds from the BCM that run into splice pack S202 and then to grounds G200 and G201. G200 & G201 are located just above where the main bulkhead connector goes through the firewall on the driver side dash. S202 is located in the wiring harness above the accelerator pedal.
tazz9690
Aug 21, 2019 10:01 PM
tim153
Feb 22, 2013 02:49 PM
midnightbluS10
Dec 7, 2010 06:47 PM
Angel Blazer
Dec 27, 2008 02:27 PM
uncthaddeus
Feb 20, 2007 11:45 PM
