Help with a common problem with no answer...
Old Apr 17, 2012 | 08:30 PM
darko's Avatar
darko is on a distinguished road
Default Help with a common problem with no answer...
at least I can't find one. please point me in the right direction...
it seems like this is a fairly common problem. I can't believe we don't have a specific write up on how to fix this issue.
96 Blazer 4x4x4 Auto
Problem: Speedometer is not working, Transmission will not shift, and ABS light comes on. As it warms up (sometimes 1 mile, sometimes 20) suddenly the Speedo will start working, the tranny will shift, and the ABS light goes off.
It has gotten worse and worse to the point where it won't shift at all (also no speedo and ABS light is always on). This has happened to many many many blazers and I can't find a single fix, just lots of "maybe it's this" or "maybe it's that". Is there a definitive solution to this very specific problem?
Any help is very much appreciated!
Old Apr 17, 2012 | 08:44 PM
pettyfog's Avatar
I answered it, here.
https://blazerforum.com/forum/2nd-ge...roblems-69994/
Your pcm is not seeing vss. The vss sensor is on the rear tailshaft. 2 wires in the plug. There may be more than one on your tailshaft. Also I dont have 96 wiring drawings or I would tell you what the pcm connection is.
Remove the connector{s}, clean them up, grease with dielectric and make sure pins are good. Then check for frayed broken wiring along the path to the engine room.
If that still doesnt do it, buy 1 new one.
Worst case: PCM bad.
Old Apr 18, 2012 | 09:33 PM
I agree, spot on perfect! Intermittent/poor connection somewhere. This is the cause of all of your symptoms.
ladylead
Aug 29, 2012 10:43 PM
E_James
Nov 3, 2011 09:49 PM
mafiaboy01
Aug 19, 2010 06:05 PM
Blasir
Aug 17, 2008 07:46 AM
blznlowxtreme
Oct 20, 2007 08:31 PM
