HELP I am lost when it comes to DTS codes
I have a dts code in my blazer. it is a 2000 model . I keep recieving P0340 cam shaft position sensor bank 1 malfuntion. When I pull up freeze frame data this is what I get:
Calc load 23.1
st ftrm1(%) 1.5
lt ftrm1(%) 7.8
st ftrm2(%) -3.1
lt ftrm2(%) 7.8
map 20.4
rpm 1878
speed 49
maf 4.922
abslt tps 25.8
I dont know what most of this means. I am self taught when it comes to auto repair. Aslo I need to figure out where this sensor is located so i can replace it if need be. My manual says one thing and various users users say different here. I have a 4.6 liter engine. manual says on front of engine perpendicular to something and some say on distributer. where is it.
Calc load 23.1
st ftrm1(%) 1.5
lt ftrm1(%) 7.8
st ftrm2(%) -3.1
lt ftrm2(%) 7.8
map 20.4
rpm 1878
speed 49
maf 4.922
abslt tps 25.8
First up if it wasn't a typo on your part you have a 4.3 engine not a 4.6.
The Camshaft Position Sensor is located in the distributor, under the cap & rotor. Remove your cap & rotor and the sensor connector and remove the 2 screws on the sensor.
Before you look to replace it however, check the connector to the sensor and the condition of the wiring.
Hope this helped.
Hope this helped.
abadinalbany
04-16-2011 12:31 PM
