help i am stuck and definiatly not a mechanic
I have just purchased (literally yesterday) a 2001 chevy blazer when i drive it there is this weird wobble in the front end. Now I have checked the lug nuts they are all tight, the air pressure is at 32lbs, and when i jack up one side to shake the tire there is only a tiny bit of movement( I am told this is ok) so i am left questioning what else could it be it does need an alignment but never have i felt a misalignment with a wobble it usually just pulls to one side i was told tie rods but there is little movement in the tire when it is off the ground is there something else i should be doing or looking at? thanks.....
you can email me at lacuna01201@yahoo.com
bent rim, bent bearing, busted belt in tire also ive had times leaving offroading where there will be a huge clump of mud stuck inside the rim and it can cause that too
jprife
08-05-2015 01:52 PM
brettseme
10-12-2010 07:00 PM
Havensk
07-25-2010 08:16 PM
kaindragoon36
03-28-2006 10:41 PM
