Help me w/ abs mod to caliper lines
Old Jun 19, 2014 | 11:12 AM
fletch125's Avatar
fletch125 is an unknown quantity at this point
Default Help me w/ abs mod to caliper lines
So today I lost all brakes while driving home. Got it in the garage and pulled the driver tire off to find that the lines that go from the abs mod down to the frame (2lines one goes to driver caliper and other goes to the other brake lines) were squirting fluid when I pushed the pedal. The clip that holds them caused them to rust and leak. Now I know I have to replace the lines but can anyone tell me what fasteners ill need? (Bubble, etc) and I believe its 3/16" lines.
Old Jun 19, 2014 | 02:18 PM
spittybays
Guest
Posts: n/a
That is a classic spot, for some reason when they made the bend at the factory it got f'd up. Of course they used the cheapest steel line.
If you have access to some other transport. Take them off, you will need to hit them with some heat, propane will do.
Take the lines to a brake shop and have them make them for you, should be no more then $50. There are so many different flares, its a nightmare.
As far as the clips are concerned, for electrical wiring they make hold down clamps that are black plastic coated, you take them and spray them with CRC corrosion protector. That should do yea!
Will take a look to show you what I'm talk'in about.
http://www.cabletiesandmore.com/stai...eel-clamps.php
Old Jul 15, 2014 | 02:51 PM
fletch125's Avatar
Insulated Stainless Steel Cable Clamps
Took me 4 days but i did it! I was very suprised but they were all double flares!!!! After i finished I discovered nickel plated copper brake line.....you can just about tie a bow with these by hand and they dont kink or break.....unfortunately I found these after I made mine with steel line!!
bassson
May 24, 2014 03:56 AM
duckland23
May 1, 2014 03:04 PM
catfishdude
Jan 12, 2014 09:21 PM
chris015
Engine & Internal
Jul 2, 2012 01:04 PM
RyanLoerch
Oct 25, 2011 03:26 AM
