Help my 2002 blazer won't start milky oil
Milky oil is caused by condensation, or coolant in the oil. The lower intake manifold gaskets leak coolant around the coolant passages between the intake manifold and the cylinder heads, (very common problem on this engine). This will not cause the no-start, but it will cause damage to the bearings in the engine, and needs to be repaired ASAP.
As for the no-start, first step is to check the fuel delivery system. This thread explains: https://blazerforum.com/forum/2nd-ge...eakdown-88305/
1996-4.3Lvortec-baca
06-04-2011 06:59 PM
gmoney30
01-22-2010 07:07 PM
