HELP! Is my Blazer going to blow up? SAFETY ISSUE
Old Dec 30, 2008 | 09:35 AM
LittleT's Avatar
LittleT is an unknown quantity at this point
Default HELP! Is my Blazer going to blow up? SAFETY ISSUE
My 1997 Blazer had the fuel-cut off valve broken when I last dropped the tank to work on it. I was told this check valve was to prevent gas from pouring in in case of a roll over situation. Is this true?
I smell the fuel when I get out of the car. I'm just afraid that this will cause a possible explosion with the cat being close by? Am I ok? Or should I not drive the vehicle?
Old Dec 30, 2008 | 10:12 AM
Blazin1's Avatar
Blazin1 is an unknown quantity at this point
Default RE: HELP! Is my Blazer going to blow up? SAFETY ISSUE
Any fuel leak can be potentially dangerous so NO you shouldn't drive it. Check underneath your truck to see if there's a visible leak somewhere. At first I didn't see my fuel leak, the only reason why I found it was because of a hissing sound it was making. I found it was a bent pastic fuel line, but then again it might be that valve, either way the gas smell indicates something isn't right.
Old Dec 30, 2008 | 04:03 PM
I would not worry about the catalytic converter much, but you really should not drive the vehicle with a known fuel leak.
Old Dec 31, 2008 | 08:07 AM
LittleT's Avatar
Well I'm not leaking fluids .... just vapors. But I guess that's not as good either.
Old Dec 31, 2008 | 07:35 PM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
ORIGINAL: LittleT
No, it'sMUCH worse than the liquid itself.
A full tank of gas is safer than a half tank of gas would you believe.
aftermath8966
Jul 12, 2014 11:54 PM
acfiero
Feb 6, 2012 06:29 PM
Shadowman
Jun 20, 2011 11:10 PM
metcalfr
Nov 23, 2009 01:07 AM
ghostrider76
Oct 17, 2009 08:15 AM
