Neutral safety switch issue
Old May 7, 2011 | 12:41 PM
Shadowman's Avatar
Shadowman is on a distinguished road
Default Neutral safety switch issue
The NSS on my 01 Blazer broke apart when I touched it. I have a repl., but I can't get the trans. into N (to properly align the new switch at install). there are two harnesses at the switch. Is there a jump to release the lock so I can shift it into N?
Thanks.
Old May 24, 2011 | 12:41 PM
To replace the park/neutral switch on the 4L60E, you have to disconnect the shift cable, remove the shift lever, and then you can remove the park/neutral switch. You should be able to manually shift the transmission by hand once the shift cable is disconnected.
Old Jun 20, 2011 | 11:10 PM
Shadowman's Avatar
Default Inconsistent start
I've replaced the Neutral safety switch and the ignition switch. Vehicle will start, but inconsistently. I cannot count on it starting every time I turn the key. Stranded a number of times.
Need advice on
1. "Security" lock out (reset)
2. Does the new neutral safety sw. need some kind of "fine alignment"??
Thank you.
chappie74
Oct 17, 2010 10:42 PM
kship3
Oct 16, 2010 03:24 PM
metcalfr
Nov 23, 2009 01:07 AM
95_4door
Apr 14, 2008 07:39 PM
blazerssuck
Dec 5, 2006 08:14 PM
