Help! Need a 4WD button expert. Lights not operating correctly.
Old Feb 16, 2013 | 08:48 AM
OhioLefty's Avatar
OhioLefty is on a distinguished road
Default Help! Need a 4WD button expert. Lights not operating correctly.
I have a 2000 Blazer LT 4X4 and the lights on my Automatic 4WD are not operating correctly. The other day when I needed 4WD, I pushed the button for "4HI" and it seemed to operate correctly but when I went to put it back in "2WD" it seemed to work but the "2WD" won't stay lit. I showed it to a friend of mine who I bought the Blazer from and has extra parts and works on them for fun and he suggested a "new used" 4WD button panel. We swapped it out, started the vehicle, it cyled through all the lights and seemed to fix the problem. I've never seen mine ever cycle through the lights when I start the engine but he says it's supposed to and his does it all the time when he starts his.
Problem is back. Last night I had to switch to "4HI" for a little bit and now it is doing the same thing as before. The "2WD" won't stay lit and the lights don't cycle when I start the vehicle. I think it is going in and out of 4WD but no functioning lights. If I hold the button in the light will stay on for a little while or flash then it goes back out.
By the way, I have the "4 button" panel with the round "Auto 4WD" button.
Can some kind soul help me out?
Thanks!
Old Feb 16, 2013 | 01:04 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
You try unplugging the switch and plugging it back in?
Old Feb 16, 2013 | 01:47 PM
johnjfeher's Avatar
johnjfeher is an unknown quantity at this point
Default Same thing happend to me!
Look at your 4wd fuse!!!! i had that same problem where it wouldnt kick out of 4wd than i looked at the fuse and bam it was blown so just check that first
Old Feb 16, 2013 | 01:59 PM
OhioLefty's Avatar
Yes, that was the first thing I tried. Thanks for the reply.
Old Feb 16, 2013 | 02:00 PM
OhioLefty's Avatar
Good idea, where is the 4WD fuse? Inside fuse box or under the hood?
Thanks for the reply!
Old Feb 16, 2013 | 02:12 PM
johnjfeher's Avatar
In the fuse box on your driver side, atleast thats where mine is located, just look for the number (it might have a sticker indicating which fuse is what)
retrojag
Sep 25, 2013 12:13 PM
vein420727
May 15, 2013 09:02 AM
dennis payne
Feb 15, 2012 10:29 AM
BearingEater
Jun 17, 2011 03:16 PM
tred2587
Feb 20, 2009 08:52 PM
