Help Needed Again!
Old Nov 18, 2013 | 06:07 PM
philipbolek's Avatar
philipbolek is on a distinguished road
Default Help Needed Again!
Hello,
Not an active forum member but you guys have helped me in the past. Thank you!
1998 Chevy Blazer, 4x4 - 4.3 Vortec - 102,000miles.
I have searched the forums already and have many options from what I have read, just wanted to post the specific symptoms and see what you guys think again. Issue is this: Changed fuel pump about a month ago, old one was bad. Changed the fuel filter as well. Car now runs but is getting horrible gas mileage, like 5 and a lot of exhaust/gas smell from the exhaust. So bad I can smell it in the house when my wife leaves the driveway. New issue started the other day where upon accelerating at around 35mph - 1800-2000rpm the engine/exhaust/under the car starts popping - kind of like back firing but not exactly. The car at times also does the traditional loud backfire when starting. Car has always been hard to start since I bought 3 years ago - crank for about 5 seconds for it to start.
So......that's it - biggest issue I have is money for parts. I don't have a code or computer to plug but I am working on it. Is there one or two areas/parts/components that you guys would look at first as the being the problem? We live in Hawaii - rural Hawaii, parts are hard to get and expensive. I did ok purchasing the wheel bearing and fuel pump on-line but parts/help is not easy/cheap to get. I have time and I think most tools.
Sorry so long - wanted to try and explain the issue and my predicament.
Thank you - any and all suggestions are welcome.
Old Nov 18, 2013 | 07:10 PM
Could be multiple issues going on. First thing is check the fuel delivery system to be sure it's doing what it's supposed to. You'll need a fuel pressure tester, most auto parts stores rent/loan or sell them. Connect it to the service port near the distributor. In the underhood fuse panel on your 98, there is a vacant terminal that runs directly to the fuel pump, and is called the "pump prime" terminal. Install a jumper wire from battery positive to the terminal:
When the fuel pressure stabilizes on the tester, make a note of it. Must be 60psi to 66psi. Remove the jumper wire. Check fuel pressure 10 minutes after removing the jumper wire and make a note of it. Must be above 55psi. Post the results.
Old Nov 18, 2013 | 07:18 PM
Ok - I will need to get ahold of pressure tester - I will check with the NAPA store here.
Thank you! - it may be a few days before I can post results.
gatelocked
Feb 28, 2011 04:52 PM
KRUSHER
Jan 2, 2010 07:25 PM
pokergirl_lynn
19
Feb 19, 2007 12:02 PM
2kSnakeEater
May 11, 2006 11:17 PM
blazin4eva
Feb 26, 2005 12:04 PM
