Help Needed With Hesitation
Old Jul 27, 2011 | 10:49 PM
bvanfossen's Avatar
bvanfossen is on a distinguished road
Default Help Needed With Hesitation
I have a 2000 Blazer ZR2 with 125k on it. I bought it last week and it has not been driven since. I've been doing maintenance on it. I had it scanned and there are no trouble codes.
It idles fine and cruises fine but at very low RPM's it has a hesitation. It kind of sputters with the load of acceleration. It clears up around 1800 RPM's.
I have been doing research but I was hoping someone knowledgeable could lend me their mind-
Thank You-
Brian
Old Jul 27, 2011 | 11:13 PM
xgiovannix12's Avatar
whens the last time you did a tune up ?
did you check the fuel pressure?
Old Jul 27, 2011 | 11:34 PM
bvanfossen's Avatar
I bought it a week ago. have not checked fuel pressure. wouldn't low fuel pressure cause it to idle poor? I will check that.
Previous owner said he did a recent tune up. But I didn't see receipts.
Thanks
Old Jul 28, 2011 | 12:29 AM
id inspect the wires , plugs , rotor and cap see how they look . Also these trucks prefer ac delco for ignition products
also remember fuel problems wouldn't light a ses light on
Old Jul 28, 2011 | 08:51 AM
bvanfossen's Avatar
I'm going to clean the egr today. Do I need a replacement gasket if I remove the Throttle Body?
Thanks
Old Jul 28, 2011 | 11:46 AM
Thanks
you dont if you dont damage it . sometimes they stick to the intake and they rip so careful
Old Jul 28, 2011 | 02:36 PM
bvanfossen's Avatar
well I didn't do the EGR. I did remove the TB and cleaned it real good. It helped- a little- with the hesitation.
I do not have a fuel pressure gauge. I went out and there was NO pressure in the fuel line. When it's running there is good pressure.
After a few minutes of being off- there is no pressure in the fuel lines. So something is bleeding off.
I do not smell fuel anywhere though. What do you think?
Old Jul 28, 2011 | 02:38 PM
the best way to find out if you have bad pressure is with a gauge .
call your local auto parts and find out if they have a loan a tool program . most of them do
Old Jul 30, 2011 | 08:15 PM
garryb's Avatar
garryb is on a distinguished road
mine was just the # 3 and 5 spark plug wires.
Old Jul 30, 2011 | 10:49 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Mine had the exact same problem. Small hesitation when getting on the gas from a stop. My problem was a clogged cat combined with a vacuum leak. Vacuum leak was the biggest contributor to the problem tho. With your engine running listen in the engine compartment for a sucking noise, and if you hear one try and figure out generally where it's coming from.
