HELP!!!!! Not sure what this is
Old Jun 18, 2007 | 04:44 PM
KIllarb634's Avatar
KIllarb634 is an unknown quantity at this point
Default HELP!!!!! Not sure what this is
Ok I changed my tires today from 275 275 17's to 265 65 17's, Left the 75's on the back just changed the fronts, I have a feeling the right front wheel bearing is going,
so i'm driving and switch into 4 hi at around 1200 rpm's from 2wd around 10 mph and hear a loud whining noise.
What would cause this and is it the bearings?
The car won't pull forward while ideling on its own, being off the brake it doesn't move forward at all feels like i'm on the brake, Truck slows down as soon as i come off the gas, like i'm braking.
Please help asap
Thanks In advance
Brian
Old Jun 18, 2007 | 04:47 PM
KIllarb634's Avatar
Default RE: HELP!!!!! Not sure what this is
Sorry,
1998 Blazer LT 4dr 4wd
Steering wheel doesn't shake
Just symptoms above
Thanks
Old Jun 18, 2007 | 06:43 PM
TripleBlackBlazer's Avatar
Can't have different size tires while running 4WD. That's the short answer, I'm sure someone will provide a more detailed answer to help you out. Bottom line though, put the same size tires on front and back (or a tire/rim combo that's the same height).
Check out this thread for a little more info, I found it with a quick search.
Old Jun 18, 2007 | 07:17 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
He is right, running different overall diameters will cause your transfer case and differentials to make noises and not work whether you are in 2wd or 4wd. If you have 4wd you can't run different overall diameter wheels and tires.
-Lenny
Old Jun 18, 2007 | 07:59 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
To better explain basically you switched from a 32" tire to a 30" tire in the front. This tire has less traveling surface and thus has to spin faster when going the same speed as the rears. When you enguage 4wd it tries to turn the front and rear at the same speed. Since the fronts are smaller they wont cover as much ground with each turn as the rears so they will fight each other. Thus thisputs strain on the transfer case and causes the whining noise that you hear.
Old Jun 18, 2007 | 09:28 PM
echo, Echo, ECHO!!! LOL
Yup, you guys covered it.
Old Jun 19, 2007 | 12:01 AM
KIllarb634's Avatar
Ok in 2wd noise is no longer there, but it was right after it happened. Thanks
Brian
dodgeman89
Jan 12, 2013 12:11 AM
AwesomeAlbert
Sep 3, 2010 12:35 PM
Kr.Fabs
Jul 1, 2010 08:08 AM
okstud
Feb 12, 2010 09:46 AM
