Help please
Old Sep 7, 2024 | 02:33 PM
  #41
matthewsjeremiah1983's Avatar
matthewsjeremiah1983 is on a distinguished road
Default Fuel pressure Test
George,
when I do the test at the filter I have to cycle the switch 2 to 3 times to get the pressure past 50psi. With the key off the pressure still is climbing to nearly 60. So my question is did I screw something up doing this test, and it’s now throwing the results off?
Old Sep 7, 2024 | 02:41 PM
  #42
GeorgeLG's Avatar
Originally Posted by matthewsjeremiah1983
George,
something is definitely wrong between the tank and your test point at the filter. That key on pressure should be much higher closer to 90 or more. Did you say that’s a brand new Delphi or AC Delco fuel pump?
George
Old Sep 7, 2024 | 03:30 PM
  #43
Yes it is a new Delphi fuel pump, with check valve. I thought something wasn’t right as I was looking for initial switch that it shoot to 90. I am wondering if the relay which isn’t new is getting hot and not allowing the pump to run long enough.
Old Sep 7, 2024 | 03:57 PM
  #44
GeorgeLG's Avatar
there are a few possibilities, but this needs to be resolved. First, the pump can be faulty, although I doubt that because that brand has a good reputation so let’s not go there for now. Second your fuel filter is clogged, so take it off and check the dead head pressure from the line without the filter. Third there’s an obstruction somewhere in the line from the pump to the filter. Fourth, you have a voltage problem at the pump. Let’s start with the dead head pressure with the filter removed and go from there.
George
Old Sep 7, 2024 | 04:29 PM
  #45
Okay I will check without the filter, but the filter shouldn’t be clogged I replaced it with a WIX filter when I done the pump.
Old Sep 7, 2024 | 05:47 PM
  #46
GeorgeLG's Avatar
Something did not go right so we need to diagnose from square one. If this is not the problem then we move on to voltage and ground at the pump. I am trying to save dropping the tank again for last because that job is a PITA.
George
newguy
Jun 14, 2016 04:02 PM
xAnarChisTx
Jul 23, 2014 09:10 PM
La Momia
Jan 11, 2014 12:28 PM
correa1020
May 12, 2013 09:10 PM
dodgeman89
Jan 12, 2013 12:11 AM
