Help please
Old Dec 6, 2011 | 03:17 PM
leroy2008's Avatar
leroy2008 is on a distinguished road
Default Help please
I have a 2001 blazer. I started with the engine dieing all of a sudden. I have final narrowed it down to no spark.I have replaced Ignition coil, Ignition model , crank position sensor, ignition switch, and no fire at the coil. I am getting power to the coil just no spark. Any help would be appreciated.
Old Dec 6, 2011 | 03:35 PM
I would start by testing the resistance (<5 ohms) across the various contacts in the ignition switch. Very common to have them go out in these trucks with widely varying symptoms. The link in the bottom of my signature below should provide the necessary information for getting that done. Let us know when you're done and the results of the testing.
Old Dec 6, 2011 | 04:07 PM
leroy2008's Avatar
I have read some post about the crazy things that could happen. Thats why I changed it out. You still think it could be it? Same problem before and after changing.
Old Dec 6, 2011 | 04:50 PM
Sorry, could have sworn that you hadn't tested those, not that you had replaced them. Probably isn't that then.
Have you tested the wiring to/from the CKP sensor?
Old Feb 17, 2012 | 04:05 PM
leroy2008's Avatar
just wanted to update my post. I got a schematic of my ignition checked everything and was checking ok. Then just happen to move wire connector to the coil and found my problem. BAD WIRE right on connector. Man what a headache for such a small thing. Looked like it was arcing and screwing with the computer. replaced wire now all is good.
Old Feb 18, 2012 | 10:50 PM
rbrace's Avatar
rbrace is on a distinguished road
Default help advise needed
i found a 2001 blazer for sale 750.00
61000 miles he said it wont start thinks
it is the fuel pump should i buy it?
Old Feb 19, 2012 | 08:19 AM
leroy2008's Avatar
About $350 for new pump. Don't get the cheapos.
It took me a couple hours to change it. Very easy to do.
If I found that deal I would jump on it. Just make sure I s the pump.
Old Feb 19, 2012 | 08:23 AM
chris015's Avatar
61000 miles and he only wants 750 for it? Make sure hes got a clear title in HIS name..sounds fishy even if it doesnt run. Make sure it turns over too.
OP
Sucks you replaced all those things for nothing. I guess you got new spark stuff now huh. I hope you replaced the ignition module with a ac delco. aftermarket modules are like the pumps. hit or miss.
opposedforces
Sep 1, 2011 02:59 PM
BlazerPunisher
Mar 23, 2009 05:47 PM
rogggg1020
Nov 11, 2008 08:05 AM
blazin4eva
Feb 26, 2005 12:04 PM
blazin4eva
Jan 27, 2005 02:02 PM
