help!! possible fuel pump problem
Old Aug 8, 2010 | 03:28 PM
cr33hill's Avatar
cr33hill is on a distinguished road
Default help!! possible fuel pump problem
i have a 95 blazer ls and recently replaced the fuel pump, exhuast and thet water pump to fix the problem i had (work done may 2010)
the problem: while driving the truck would randomly start to jump like if you were pushing the gas down and up. like you were pumping it. my foot would gently be pressed on the gas and it would do this.
replacing the things above fixed it but this has happend recnetly even after the work was done any suggestions??
Old Aug 8, 2010 | 05:17 PM
Have you checked the output from the TPS sensor? It should be ~0.5V at closed throttle and smoothly increase to ~4.5V at wide open throttle.
Old Aug 9, 2010 | 05:36 PM
cr33hill's Avatar
havent checked it no... im not much of a mechanical guy.. how could i do it myself??
thanks a bunch for the help
BouncingRadical
14
Nov 27, 2015 12:30 AM
davidh9732
Aug 28, 2010 12:57 AM
57butler
Mar 29, 2008 01:36 PM
mytruck2
Dec 13, 2006 04:50 PM
ServiceGames
Oct 12, 2006 04:01 PM
