Hesitation Upon Starting
I have a 96 Blazer that hesitates when starts but if I turn it off an on again it works perfectly fine, so far, I've changed spark plugs, spark plugs cables, distribuitor cap and rotor and still having the same issue, by the way I don't have the check engine light on don't know if it doesn't work. I'll appreciate all the advices and help you experts could give me.
Welcome to the forum. The only thing that I can think of is ur fuel pump is starting to act up or a dirty fuel filter. I've heard some people have issues with the fuel pressure if they start the blazer to quickly, do you wait until the chimes stop dinging?
No, once I put the key on the switch I turn it on but it's when starts to act up so I need to yo turn it off an on.
After you turn the key on (but before attempting to start), listen for the electric fuel pump in the tank near the rear driver side wheel. You should hear it buzzing. That won't mean its working completely, but if you don't hear it you'll know its not.
I would check the fuel pressure. Some of these don't get to the proper 'plateau' until like 3-5 seconds. Or you could key on then off for 10 seconds for 2-3 times to see if the proper pressure is achieved..so..for no cost (except for the tool or you might have or know someone whom does) check the fuel pressure or..key in on (don't start) for the duration of fuel pump energization (approx 2 seconds) then key off for 10 seconds..do this 3 times then start...if it starts good, likely a sleepy fuel pump...
Thank you for your advise, I hear the buzzing once I turn the key on, I will check the fuel pressure.
I'm with Perumotors on the possibility of a lazy fuel pump not being all the way up to pressure after one 2 second pulse, requiring several key cycles to get it to run correctly. Maybe even a plugged fuel filter.
