Hesitation Upon Starting
Thank you, I will change the fuel filter first and will check back again with you guys.
i have a 2004 4 door 4 WD 4.3 and is doing what you said,it will start fine most of time from cold,drive around to couple places then no fuel pressure when crank-i checked with gauge one time in driveway when wouldn't start-so i found crank couple seconds turn of for about ten seconds try again so far will start after few attemps.It is a fuel pump from advance,second one,people say go with better brand,i think that is good idea.Runs fine after starts,may swap with horn relay just to see if any difference.
