Het and ventialtion issues, 01 blazer
Old Sep 16, 2009 | 01:26 PM
bman416's Avatar
bman416 is on a distinguished road
Default Het and ventialtion issues, 01 blazer
So it continues. I decided to turn the heater on today just to make sure it works. The temp was up on the gauge so i blasted the heat. First i smelled what i figured is antifreeze and the heater doesn't blow very warm at all. a friend said water pump. I thought heater core.
Also, no matter what spot setting is on ( defrost, down below or dash vents) the dash vents always seem to be blowing air, more so when it is on that setting.
Also again, when ventilation control is off, i hear what sounds like a hissing noise. once you turn the dial from the "off" position the hissing goes away. thanks to all who answer. Hopefully down the road i can help answer some questions.
Brian
Old Sep 19, 2009 | 06:51 AM
bman416's Avatar
Can anyone help me on this one? At least the first question. Not too crazy on the smell of antifreeze. Winter is around the corner and when i pick up my 5-month old son after work, i think he may enjoy heat in the truck. lol. Thanks.
Brian
Old Sep 20, 2009 | 09:11 PM
19blazer95's Avatar
19blazer95 is an unknown quantity at this point
Seems to me u have a combination of problems. A smell of antifreeze in the cabin is most likely a leaking heater core ,have the systems pressure tested by a shop.You can do the work yourself but it does involve taking the dash apart.As far as the vents, could be a vacuum problem. Sound like the switch (Round Dial ) is leaking at diffrent positions.I will try to get u a schematic for the vacuum lines for u to check them but i looks to me its the switch. rockauto.com has those switches i believe. good luck
Old Sep 21, 2009 | 03:11 PM
bman416's Avatar
thanks 19blazer95. I just checked that site. They sell the whole module with all three dials for $77. is that the one youare talking about when you say "switch" or do you mean the individual dial that does the defrost, dash vent and such? the dial on the far right.
Brian
Old Sep 21, 2009 | 07:47 PM
96blazerky's Avatar
96blazerky is on a distinguished road
it could also be the blend door motor or the blend door itself. i kno fords have a problem with their blend doors messing up but never heard about blazers havin this problem but of course things do break
Old Sep 22, 2009 | 04:25 PM
roy45693's Avatar
roy45693 is an unknown quantity at this point
I put a new battery in my 98 with climate control and now the blend door cycles constantly from hot to cold. Any help out there?
Old Sep 23, 2009 | 04:32 AM
awe341's Avatar
awe341 is on a distinguished road
Roy45693, read through this thread and you should be able to solve your issue.
https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/electronic-air-heat-control-continous-cycling-20633/
bman416, if your truck has the three separate dial switches then you should be able to just replace the one selector switch rather then the whole unit. It will depend on your make/year if you have three individual switches or if you have to replace the whole assembly. No way to know for sure till you remove the old one.
daemeon2
Jan 6, 2013 04:06 PM
99slobra
Jan 3, 2013 05:02 PM
DimeBlazr
Jan 2, 2013 01:05 PM
cruukedeye
Jun 4, 2011 06:49 PM
dragonsdeath
Oct 7, 2006 01:08 AM
