hey yall! new member
Old May 7, 2011 | 12:27 PM
batteringram03's Avatar
batteringram03 is on a distinguished road
Default hey yall! new member
this is my first post so please bear with me...I recently changed plugs on my 2003 blazer,and i had to pull the steering shaft(thanks GM!)Now my steering wheel isn't centered while going straight down the road.Any suggestions?If this is in the technical forums please steer me in the right direction.Thanks all!
Old May 7, 2011 | 12:31 PM
rriddle3's Avatar
*Moved to '2nd Gen Tech'*
Old May 7, 2011 | 12:58 PM
TheRandom1's Avatar
There are a couple ways that I know of to do this.
One is to have your tie rods adjusted to center your wheel while the vehicle is going straight.
The other is to remove the shaft again with the tires pointed straight forward, then rotate it so your steering wheel is pointed straight again, then bolt it back together.
One costs money, the other is a bit of a pain. Good luck with either option!
Oh, I suppose there's a third option too actually which is to remove the steering wheel and recenter it that way.
Since the issue seems to have been caused by the steering shaft being removed, I'd probably go that route.
Last edited by rriddle3; May 7, 2011 at 05:18 PM. Reason: COMBINING CONSECUTIVE POSTS
Old May 7, 2011 | 03:43 PM
The steering shaft has a flat spot so it can only go onto the rag joint one way.Looks like no adjustability is possible there...but im no rock scientist
Old May 7, 2011 | 03:46 PM
TheRandom1's Avatar
I never looked, was just guessing haha. In that case, I can't think of any reason at all that your steering should be off then.
ericthughes
Jun 15, 2011 09:19 PM
BIG BOY TOYZ OFFROAD
Sep 10, 2009 06:16 AM
Rebel customs
Jun 5, 2009 07:05 AM
smoothedoggie
Feb 14, 2009 01:53 AM
tx78k5blazer
Mar 20, 2008 08:09 AM
