hey yall i got vacuum lin e question
Old Jun 14, 2011 | 10:25 PM
ericthughes's Avatar
ericthughes is on a distinguished road
Default hey yall i got vacuum lin e question
1978 chevy blazer crate 350 GM
so i changed my EGR valve just to rule out i have a bad valve. i also changed my EFE TVS valve a whiule ago so ive come to the conclusion by looking at my service manual that my vacuum lines must be totally backwards ....but my thing is it passed smog befor so im reluctant to switch it to the way the manual says.ive got two outlets to my charcoal canister blocked off. but in the manual it has lines going from all 4. the one thing that confuses me is that in the maual it says to air cleaner ("G only")what does that mean? im just a little confused because i have **** with 3 way splits to stuff the re routs back to the EFE TVS valve anyways my question it what does all except "G" means i cant find nothin in the service manual that explains that .im looking at the vacuum hose schematic for a v8 350 cid -ld emissions it looks like my vacuum schematic because its the only one with the dts&efe tvs valve with 4 outlets on it ..im ramblein on but my questions are what does that to air cleaner G only means ans should i go ahead ahead and go by this schematic even though mit passed smog befor even though it still runs ****ty?
Old Jun 14, 2011 | 10:47 PM
6.2 man's Avatar
6.2 man is on a distinguished road
G is for Chev Vans and as far as your lines go I would check the advance and egr lines at idle . If there is no vacuum thats great !!! Rev it up and you should have vacuum as for as the canister you don't need vacuum . Just my 2 cents .
Old Jun 15, 2011 | 08:09 PM
im at a freakin loss..
Old Jun 15, 2011 | 09:19 PM
oisinirish's Avatar
Did you check the thermac valve in the air intake. My air temp sensor is bad so it always tries to close when the lines are hooked up. Definitely caused operational issues. Also make sure they're not backwards. Will cause the same problem.
batteringram03
May 7, 2011 03:46 PM
BIG BOY TOYZ OFFROAD
Sep 10, 2009 06:16 AM
Rebel customs
Jun 5, 2009 07:05 AM
smoothedoggie
Feb 14, 2009 01:53 AM
tx78k5blazer
Mar 20, 2008 08:09 AM
