High Idle after flood waters + high rpm shifting
Old Aug 14, 2014 | 07:56 AM
mcdevin1973's Avatar
mcdevin1973 is on a distinguished road
Default High Idle after flood waters + high rpm shifting
Hey Guys,
So there was a flood here and my 2000 LT stalled out. I replaced the air filter, dried out the air intake arm, the MAF sensor and changed the engine oil and eventually it started up. I also checked the trans fluid for water on the dipstick and it doesn't seem to have water on it.
A day or two later its been idling high at start-up, 1500 rpm, and its been revving higher than normal on first shift. Also, I'm not getting the check engine light on the dash (yet). What could be the problem?
I read that it could be the TPS or the IAC.
Lastly, can I drive it on the highway in the meantime until I can replace/check the sensors?
Old Aug 18, 2014 | 04:45 AM
Fixed it! Throttle position sensor on the throttle body. It has 2 torx screws though so be ready for that and you'll have to remove the upper radiator hose clamp and disconnect the hose.
Old Oct 4, 2014 | 07:47 PM
Rathbone's Avatar
Rathbone is on a distinguished road
Sounds like the problem I have. So you replaced the TPS or just adjusted it? I don't even know what it looks like.
Old Oct 5, 2014 | 02:52 PM
Aeromaster's Avatar
Aeromaster is on a distinguished road
When I hit some high water last winter Got about a half mile and engine started running weird. High idle and then stalling out. Thought it might be the TPS, but turned out that the engine must have choked or backfired in the intake and popped the MAP (Manifold Absolute Pressure) out of the upper intake. Shoved it back in and back to normal.
dbaas
Jun 5, 2015 05:43 PM
Tofubadguy
Aug 11, 2014 05:29 PM
matt9589
Jul 14, 2013 11:11 AM
MJ176
Sep 5, 2012 07:03 PM
pnice74
Jul 9, 2009 12:47 AM
