high-pitched sound? brake change indication?
Old Sep 16, 2010 | 07:36 PM
ashapos's Avatar
ashapos is on a distinguished road
I started hearing a low volume, high-pitched sound today. It is coming from a rubber tube coming off of the box that is located behind the fuse box (closer to the driver, when facing vehicle it is in the back right corner). Is this the change brake pads sound, or something else? It seems to be generated by the cable, which feels as though it is vibrating.
In addition, I've recently had a lot of problems with it. I've been crunched for time so I had the dealership replace the intake manifold gasket (which i'm hoping this is not related), replaced the radiator, and did a coolant flush. It has 103,000 miles
Last edited by rriddle3; Sep 16, 2010 at 08:06 PM. Reason: COMBINING CONSECUTIVE POSTS. PLEASE USE THE 'EDIT' BUTTON TO ADD TO A POST OF NOBODY HAS YET RESPONDED.
Old Sep 16, 2010 | 08:11 PM
rriddle3's Avatar
That sounds like a vacuum leak. Can you post a picture of the tube and the box you're talking about?
Old Sep 16, 2010 | 11:03 PM
ashapos's Avatar
Default a picture of the tube that i think is making the noise
The issue has been resolved. It was a vacuum leak. I duct-taped the leak and that fixed it.
Attached Thumbnails high-pitched sound?  brake change indication?-partproblem2.jpg   high-pitched sound?  brake change indication?-partproblem3.jpg   high-pitched sound?  brake change indication?-partproblem1.jpg
VTGuy1999
Sep 21, 2011 07:46 PM
CBlazer99
Mar 31, 2010 01:29 PM
mhollis
Aug 12, 2009 08:07 PM
JR Blazer
Apr 2, 2009 06:56 PM
rbennett55
Aug 3, 2006 02:38 PM
