High RPM Voltage Drop
Old Dec 14, 2011 | 01:18 PM
rednekk's Avatar
rednekk is an unknown quantity at this point
Default High RPM Voltage Drop
Noticing on my 2000 Bravada that when the RPMs climb above 4000, the voltmeter drops pretty sharply - down to about 11 volts or so. When the engine speed decreases, the volts come right back up again. Also, if the AC is running, it stops blowing cold as well.
The only common thread I'm seeing is the serpentine belt. Could this be indicative of a failing belt? It looks fine by visual inspection and there is no squealing or burnt smell that would indicate slippage. Thanks!
mcdevin1973
Oct 5, 2014 02:52 PM
2001Blue
Dec 31, 2010 12:16 PM
zedartwo
Dec 26, 2009 10:35 PM
guywm25
Aug 25, 2008 12:37 PM
ltown21
Dec 9, 2007 09:39 PM
