Is his LIM install guide correct?
Old Oct 22, 2010 | 07:03 PM
dobyken's Avatar
dobyken is on a distinguished road
Default Is his LIM install guide correct?
In the sticky helpful posts section is a link for replacing the lower intake manifold for a 99 GMC 4.3L. In the summary section is says to torque the bolts to 35 ft lbs. All the other guides and I saw and the one I used says 132 inch lbs which I thought equals 11 ft lbs. Is the GMC 4.3L different? Just having one of those "Did I screw up" moments.
http://www.handymanlyness.com/archiv..._99_Jimmy.html
Installation:
  • Set new gaskets in place and apply silicone to flat areas on front and rear of engine block.
  • Apply thread locking compound to manifold bolts.
  • Install manifold and tighten bolts to 35 ft-lbs, in proper sequence.
  • Install distributor.
  • Install upper intake manifold.
Old Oct 22, 2010 | 07:13 PM
DO NOT torque them to 32ftlbs. THIS POST has the proper information.
Old Oct 22, 2010 | 07:42 PM
dobyken's Avatar
Good..I feel better now. What would happen if someone followed those instructions? Warped manifold?
Old Oct 22, 2010 | 08:07 PM
If you don't snap off a bolt, you will most certainly over compress the gasket, compromising its integrity.
Bolbol
May 23, 2015 09:12 AM
Joey1986Z
Jun 23, 2014 11:09 AM
jacobcnc
Apr 23, 2011 09:55 AM
mysons95
Oct 29, 2008 04:58 AM
felonyblazer96
Tires and Wheels
Nov 11, 2007 08:53 PM
