Hitch Receiver Fitment Issue, 2nd Gen Blazer
This post is an account of my personal experience, and a heads-up to others, concerning a fitment issue affecting a type of Class III hitch receiver sold under the Curt, Draw-Tite, Reese, (and other) brand names, intended to fit 2nd Gen S-10 Chevy Blazers. These receivers have vertically oriented mounting flanges intended to straddle the outside surfaces of the rear frame, as opposed to 1st Gen receivers which are bolted to the bottom surfaces of the frame (Fig.1).
The 2nd Gen frame is 40 3/4 inches wide at the mounting location, so you would expect the receiver to have a dimension just slightly larger than that, just enough to allow for easy installation. But no, these receivers, like the Curt model 13300 that I bought, have a dimension between the mounting flanges of 41 1/16", resulting in a 5/16 inch total gap between the frame rails and the mounting flanges (Fig.2). And, as if that wasn't bad enough, the 1/2" grade-5 carriage bolts they supply won't go through the 12mm frame/bumper bracket holes (Fig.3).
I had a running email conversation with Bill at eTrailer.com about this, but the problem was above his pay grade. He could only say it's the one his "rep" says is for my '99 Blazer. So, I explained the issue to another dealer, who was running a sale on the DrawTite brand, and asked them to check the distance between the mounting flanges on that brand. The response was, "putting it alongside the Curt, they're identical".
So, I got hold of the upper part of the assembly drawing (Fig.4), where you can see 3 different dimensions for the mounting flange width. The dimension in red, 40.875, would be a big improvement leaving only a 1/8" gap, but the smaller of the min/max numbers in the black box near the top (40.785) would result in a virtually perfect fit. But mine and, apparently, all the other brands are being assembled WIDER than the specified MAX dimension!
I mentioned all this to Bill at eTrailer, but the best he could offer was a refund if I packed up everything I bought and sent it all back. And I almost did that, because I was definitely not going to allow that receiver to strain, stretch, or distort my frame rails, which is exactly what would happen when the bolts were tightened if something wasn't done to reduce that gap.
So I bit the bullet and had some shims made up (Fig.5) which, of course, added way too much $$ to the project cost - especially since I had to buy 6 of them just to get the fabricator interested. But after putting a shim on each side and opening the 12mm frame holes to 1/2", the fit is virtually perfect, but this was way more trouble and expense than necessary if the receiver had just been made accurately to begin with.
I'd send a copy of this post to the fabricator who's making these things if I knew who they were.
Figure 1
Figure 2
Figure 3
Figure 4
Figure 5
Figure 1
Figure 2
Figure 3
Figure 4
Figure 5
Wow. That is horrible that you had to deal with such a fitment issue. Someone less familiar with working on vehicles would have simply tried to brute force the part to fit with who knows what nasty outcome. This is not very impressive of Curt!!!
I'm not really blaming Curt. All the other brands are selling the exact same product, just with different labeling. They're all trusting, whoever it is that's making these things, to make them right. There's also a different design with different specs that uses a straight square tube instead of the curved round tube. That one hangs very noticeably below the bumper on each side. I have no information on it's fitment, but I wouldn't be surprised to hear it has the same problem.
Jase1979
07-20-2012 05:51 PM
1994BlazerS10
11-10-2009 11:06 PM
