Hole in Tranny Housing Leaking Oil?
Old Oct 21, 2008 | 07:45 AM
95Blzr's Avatar
95Blzr is an unknown quantity at this point
Default Hole in Tranny Housing Leaking Oil?
I have a hole in my tranny bellhousing. Went under this this morning and thought it was my oil cooler lines. I have a small hole and was wondering if JB weld would work. This is my daily driver. I will have some pics later after I wake up. Also would it be leaking tranny fluid. It is petty wet down there and couldn't tell if it was oil or dexron. Anyway just seeing if anyone had this problem.
Old Oct 21, 2008 | 12:51 PM
punxweb's Avatar
punxweb is an unknown quantity at this point
Default RE: Hole in Tranny Housing Leaking Oil?
Use Marintex. It is the best stuff for this. Must be clean and free of oil residue. Rough up with some rough sand paper and apply. Then file away what is not needed. This is what alot of tranny shops use.
Old Oct 21, 2008 | 02:59 PM
Duntov's Avatar
Banned
Duntov is an unknown quantity at this point
J-B Welld is a perfectsolution and it is a permanent repair. Iused J-B Weld to repairwhat appeared to be a nail hole in an oil pan and there was not a sign of a leakten years later when I sold the car. I applied theJ-B Weld two-part epoxywith a ice cream sitck and smooth it down neatlyand gave it a light coat ofengine colorfrom a rattle can and I never saw evidence of the hole again. You could spot paint your transmission case with flat aluminum spray paint and the repair will disapear.
Old Oct 21, 2008 | 03:06 PM
95Blzr's Avatar
I think I fixed it. What actually happened or what looked like was when someone was offroading(not me as the 4x4 doesn't work); A big *** piece of something got wedged between the driveshaft and oil pan and took out a big clunk of the aluminum right in between the bell housing and oil pan. Which in effect left me with a hole. And we know how easy oil pans are to replace on the 4.3's. So i got some jb weld epoxy putty. I think it's working so Ill give it a few days and update you guys. Thanks for the help. Next up water pump and oil cooler lines! yay!
cahlersmeyer
23
Nov 10, 2011 09:23 PM
Tortex53
Aug 27, 2010 12:05 AM
Mjseyler
Jan 5, 2010 12:44 PM
carlo
Apr 10, 2008 01:38 PM
Jetfixer
Jul 11, 2006 05:02 AM
