Holly 4160 Carb Problem
Old Jul 6, 2008 | 06:14 PM
vadatara2's Avatar
vadatara2 is an unknown quantity at this point
Default Holly 4160 Carb Problem
I hope I have the right forum for this question-Anyway, I have a 350 Chevy with a Holly Model 4160 600 CFM carb., vac. secondaries. I recently put a rebuild kit in and can't seem to fix this problem. The engine idles perfectly and runs out very well. When you shut down the engine gas continues to run into the secondaries and leaks out around the throttle shaft. You can remove the inspection screw in the side and the is no gas over this level so apparently the needle valves are working properly. Until the pressure from the electric fuel pump is releived this leak continues. Any ideas??
Thanks!
Old Jul 14, 2008 | 07:16 PM
vadatara2's Avatar
Default RE: Holly 4160 Carb Problem
To anyone who has experienced similar problems, I have found that putting a pressure regulator in line and reducing the 6 lbs of line pressureto 2 1/2 lbs solves the problem. WAHOO!!
Brandon Smith
Dec 22, 2013 12:33 PM
Bulletmarsh
Oct 23, 2008 12:35 AM
Manley_pm
Dec 19, 2005 11:18 PM
jotajota
Engine & Internal
Dec 11, 2005 11:45 AM
zero psi
Engine & Internal
Dec 11, 2005 12:20 AM
