problem with carb.
Old Oct 2, 2008 | 12:17 AM
Bulletmarsh's Avatar
Bulletmarsh is an unknown quantity at this point
Default problem with carb.
i bought the edelbrock carb 600cfm manual choke 1405 is the part number. k, the problem is i had a holley 4 barrel carb that leaked. so i bought the edelbrock carb and i cant find a carb kit and my throttle cable, the cruise control cable and transmission line wont go on the carb. what do you guys recommend? is there a carb kit for my carburateur
Old Oct 6, 2008 | 02:34 PM
Default RE: problem with carb.
anyone please help i cant find it and i only have 1 month before the snow hits
Old Oct 6, 2008 | 02:51 PM
So you just need the connections to your cruise, throttle, and kick down cable? Is the throttle linkage on the side of the carb even spaced like your original carb? If not, then most carbs require the removal and replacement of the primary throttle shaft to swap the bracket on the end.
Old Oct 23, 2008 | 12:35 AM
oh ok yah the major problem is theres no place to connect it and no parts that i can find such as a plate ect to hook everything up
Brandon Smith
Dec 22, 2013 12:33 PM
vadatara2
Jul 14, 2008 07:16 PM
Manley_pm
Dec 19, 2005 11:18 PM
jotajota
Engine & Internal
Dec 11, 2005 11:45 AM
zero psi
Engine & Internal
Dec 11, 2005 12:20 AM
