Hot air blowing out of vents when ac on
Ok I had some work done on my blazer this week had a new Transfer Case Control Module a new Transfer Case Actuator Motor and an 4x4 Control Switch would this cause hot air to come out of the vents now??
To answer your question, No the temperature valve(door) actuator is not related to any of these directly, but then again, If a "mechanic" is going to sell you all three of those parts to fix your 1 problem, then he is probably capable of just about anything! I'm sorry you got robbed to fix your 4WD, but there is no way that all three of those parts were bad! As for the temp valve open your glove box and reach up in the top left corner to release the stop for the door. When you push on the release you can then lower the glove box door all the way down and access the hvac case behind it. Look up on top of the case and there is a little electric motor with a 3 or 5 wire connector on it...with your ignitionon, watch the top of the motor and see if the shaft rotates when you turn the temp knobv on your hvac control head. If it doesn't then you probably have a bad actuator...let me know if it does.
If you go into your profile and add your vehicle info in your signature, it would help us out with a quick reference to what we are looking at.
Check lastcoupes' reply and let us know.
Ok mabye I I dont know what I'm looking for but I got the glove box down and did not see any thing like you siad just seen a door opening and closeing when I went from max ac to ac but no motor moving with temp **** unless i look at the wrong thing thank you again for the help I appreciate it.
msfan324
Oct 19, 2012 02:27 PM
Nikoli
Mar 18, 2011 06:23 AM
ravenhurst
15
Apr 26, 2009 07:53 AM
bl_zer
Nov 23, 2008 11:14 PM
ItradeNDX
Feb 3, 2006 05:21 PM
