How to disable dlr,s
Old Jul 7, 2017 | 01:37 AM
johnnylovsey's Avatar
johnnylovsey is on a distinguished road
Default How to disable dlr,s
I mean to disable them only each start and the next start you have to do it again. This procedure don't involve cutting any wires or adding any relays just simple way to disable them each time you get into the car and after you turn it off it needs to be done again. You ready for this when you enter the car and stick the key in or start it after the chimes stop push the Dome disable button four times and after the fourth time it chimes once and the DLR,s are disabled and will go back to normal once you shut the key off. Then the next time you start the car if you want them off do the dome bypass after the chimes are all done four times and after the fourth it will chime once DLR,s are disabled. So like I said try this method it beats cutting anything or pulling fuses trust me it works great every time.
Old Jul 7, 2017 | 06:33 AM
rriddle3's Avatar
Yes, that is the standard procedure to do it, according to the manual.
Old Jul 8, 2017 | 11:17 PM
Not everyone got a Manuel in there glove box. But thank you for that.
Brianator99
Nov 27, 2010 10:39 PM
Spectreblazer
Mar 9, 2010 12:39 AM
bdubs
Apr 27, 2009 04:23 PM
AutomagicLS1
15
Dec 22, 2007 08:15 PM
mleasure
Jun 7, 2006 09:58 PM
