how do i adjust the camber
Old Oct 18, 2007 | 10:34 PM
marlboromanx1875's Avatar
marlboromanx1875 is an unknown quantity at this point
Default how do i adjust the camber
i have a 2003 s10 blazer i recently noticed that the top half of my tires in the front are moved inward towards each i suspect the camber is off how do i fix this problem and can i do it myself thank you
Old Oct 18, 2007 | 10:36 PM
thegr81's Avatar
Default RE: how do i adjust the camber
i would suggest just taking it to an alignment shop and have them do it because without a machine doing it old school takes alot of time plus with an alignment rack they can get it right on target for you
Old Oct 19, 2007 | 02:17 PM
thanks ill do that had to find out if i could
Old Oct 20, 2007 | 12:02 AM
blzR's Avatar
blzR is an unknown quantity at this point
I thought i was going to be a smart backyard mechanic and do my own on my mustangs tierods. I took the meas straight from the old ones @13inches&2mm in lenght,applied to the new ones,then took to shop and asked them to tell me how much i was out. beingonly1 lousy degree out was no duplicatealignment for a road worthy auto was my soon realization, as they said that was out a mile in the aligment world.
Old Oct 22, 2007 | 02:52 PM
TetanuSshot's Avatar
TetanuSshot is an unknown quantity at this point
check your ball joints. jack up the truck by the frame one side at a time(so the wheel is free) and start it up, turn the wheel all the way until the ps pump grunts. if the wheel 'pops' up right before the pump grunts, the lower bj is bad. obviously you need another person to help you with the pass. side. if you don't noitice anything, with the tire about 1.5 inches off the ground, take a 2x4 or big prybar, or something similar and put the end of it about 2-3 inches under the tire and pry up on it while someone is looking at the bj. if you see any slop, its bad. if left for too long, the wheel bearing on the opposite side will go bad. trust me, i've replaced enough of them. if the lowers look good, you can usually pull on the top of the tire (with the wheel off the ground) and feel some play.
Old Oct 22, 2007 | 10:37 PM
thanks ill try that to didnt even think about that one
Old Oct 24, 2007 | 02:43 PM
blzR's Avatar
ORIGINAL: TetanuSshot
Also should note, if left bad forlenght of time, the control arm/or where ever the BJ is from, will go 'out-of-round- making one purchase a new arm/fitting to make things true again.
midnightryder
Dec 29, 2009 02:43 PM
Easy 8
Jan 2, 2008 06:58 PM
Bonovox
Sep 5, 2007 06:25 PM
e602
Aug 21, 2006 08:05 PM
96Ls4Dr
Feb 10, 2006 12:20 AM
