How do I identify my gearset in my front differential?
Old Feb 10, 2009 | 04:58 AM
carcomp's Avatar
carcomp is an unknown quantity at this point
Default How do I identify my gearset in my front differential?
I'm new here, and I'm at work so searching is limited.. but,
I have a 1997 GMC Jimmy SLT (which is pretty close cousin to the blazer) that has a damaged front differential. I think its missing a tooth or two due to an extreme situation. I just would like to know how to go about figuring out the ratio so I can replace it.
I've posted an exact carbon copy picture of my vehicle below.
http://www.autoseekandsell.com/userimages/Jimmy1.jpg
I'll spend some time searching the forum and visiting this thread. I only get 10 minutes each break
*COMBINING CONSECUTIVE POSTS*
http://www.s10forum.com/rpo/index.php
Please use the 'edit' function to add to an existing post is nobody has replied within 24 hours. Thanks.
Old Feb 10, 2009 | 05:28 AM
carcomp's Avatar
Default RE: How do I identify my gearset in my front differential?
n/m.
Old Feb 11, 2009 | 11:09 AM
Fivspeed's Avatar
Fivspeed is an unknown quantity at this point
The front ratio will be the same as the rear ratio. Inside your glove box you should see a long list of three character codes (RPO codes). If you search this website or the internet in general, you will be able to decipeher the codes and figure out what ratio you have.
Old Feb 11, 2009 | 12:25 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
look in the glovebox at the RPO codes.
GU2 2:73 ratio
GU4 3: 08 ratio
GU5 3:23 ratio
GU6 3:42 ratio
GT4 3:73 ratio
GT5 4:10 ratio
GQ1 Open Differential Rear Axle
G80 Positraction/Locking Rear Axle
I am gonna guess you have GU6 3:42 ratio
Drew4711
Oct 6, 2012 12:47 PM
PROJECT85K5
Dec 6, 2009 10:55 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
drefda
Mar 27, 2007 11:07 PM
LeigerReign
Apr 22, 2006 06:05 PM
