How do you remove the fuel pump out of the tank?
Old Nov 23, 2011 | 10:45 PM
Thogert's Avatar
I will have to, I'll have to be on my toes untill then won't I?
Old Nov 23, 2011 | 10:50 PM
xgiovannix12's Avatar
I would ... =P
Old Nov 24, 2011 | 04:31 PM
Thogert's Avatar
Ok, so my fuel pump wont turn on as you know. I've replaced the relay and I notticed that the ecm ignition fuse blows when I try to start it. Any thoughts as to why?
Edit: Ok, I think that the fuse was blowing because I was bypassing the relay to see if the pump would get power. And it did. but it wouldn't start. What am I missing?
Old Nov 24, 2011 | 04:44 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
you have a short somewhere or its wired incorrectly. Possibly the wrong pump. Got a part number handy?
Old Nov 24, 2011 | 04:48 PM
Thogert's Avatar
But the pump looked the exact same and had the same hardware with it. Why wouldnt the computer give the signal to the relay to power the pump?
Old Nov 24, 2011 | 05:14 PM
in 95, the 4.3L came in CPI and TBI versions. One rund on 9-11 psi and the other 50+ psi, IIRC. Just because the pump looks the same doesn't mean its the same internally.
Old Nov 24, 2011 | 05:18 PM
Thogert's Avatar
When I jumped the relay I could hear the pump turn on. When I turn the truck on there is nothing.
Old Nov 24, 2011 | 05:48 PM
pettyfog's Avatar
This is 99 so will be some different than 95 {think wiring changed in 97 IIRC}
Is there anything else not working? Do you have spark when you crank?
Do all inst panel warning lights light on key on?
Attached Thumbnails How do you remove the fuel pump out of the tank?-fuel_pump.jpg
Old Nov 24, 2011 | 05:52 PM
yea i think they changed the systems for 97 +
Old Nov 24, 2011 | 06:31 PM
Thogert's Avatar
Ok so I bypassed the relay again to please my mom and I got it to run perfectly. So I'm guessing the wire to or from the ignition has been grounded or broken.
