how many CCA is your battery???
Old 10-19-2007, 06:52 PM
rriddle3's Avatar
Default RE: how many CCA is your battery???
ORIGINAL: drperry
Unless you see -4 or colder on a regular basis, you won't need anything more than the stock battery...
The thing about getting the higher CCA battery is that it will usually be the one with thehighest reserve capacity which can make a difference if you run any accessories without the engine running.
Old 10-19-2007, 07:32 PM
drperry's Avatar
The OP was saying he needed a newer & bigger battery for winter...
Old 10-19-2007, 08:23 PM
gocartone is an unknown quantity at this point
Got the truck back today has a 650cca in it.
Old 10-22-2007, 05:07 PM
Mr Blazer LT is an unknown quantity at this point
Yeah, you should only be concerned if you get negative temperatures and if you're gonna deal with negative temperatures, also get an engine block heater. Cost is basically the same as a battery upgrade (up here at least). I had the stock battery for half of the winter last year and itwas good with the coldest temps in the single digits.
Old 10-22-2007, 05:57 PM
drperry's Avatar
My truck comes with a 690CCA battery in it, thanks to AC Delco...
On a side note, taking off that annoying battery sleeve makes installation of the battery 10 times easier...
It feels and looks like it frees up 1/4 inch or so of space around the battery...
Old 10-22-2007, 07:37 PM
Mine is also 690 CCA and 825 CA. Everlast Maxx, Wallyworld.
Old 10-29-2007, 10:31 AM
DCFluX's Avatar
DCFluX is an unknown quantity at this point
I seem to be having problems with my Optima red top, doesn't seem to like lasting through a weekend. Apparently it has a 3 year warrenty so I shall try my luck at getting a replacement at Autozone.
Old 09-02-2009, 10:23 PM
Ikester is an unknown quantity at this point
same with mine, hey same truck too! woohoo
Old 09-03-2009, 09:00 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
yah mines a walmart 650cca its been in there for about 3yrs no issues yet,it cranks over fast in the winter and ive jumped off of it
Blazer51
13
07-14-2012 06:03 PM
JShark
07-21-2010 01:44 PM
94_Blazed
03-10-2010 06:40 AM
ExplicitYourSelf
11-12-2009 09:52 PM
blazerJim1701
08-19-2009 11:15 PM
Quick Reply: how many CCA is your battery???
