HOw much time and work into changing unviersal joints?
I just picked up new universal joints for my 95 and was curious how much time and effort will go into replacing them? Just looking for some sort of idea how long and what i am getting into.
Thanks
Shawn
Thanks
Shawn
IIRC the stockers have nylon plugs in them, correct? You will just have to unbolt the driveshaft from either end, heat up (slowly) the plugs until they squeeze out, some persuasion to hammer out the old ones (be easy), reinstall new ones, bolt driveshaft back up. Be sure to mark everything with lines using a sharpie so it all goes back together the way it came apart or you could end up with a nasty vibration. I believe we tackled mine in no more than half an hour...
Did mine in a couple hours. Dropped my rear driveshaft, used a rental u-joint/ball joint press kit to try and press the worn OEM joint out. Failed. Took entire shaft to Chevy dealer, guy in service said should be able to press out with vise and sockets. I told him I doubted it, and he was nice enough to use the shop 20-ton press. Later on, he agreed with me, said bench vise would have been impossible. Torching the shaft doesn't sound like fun either. Thanks, Westgate Chevrolet!
That was the solution to my driveline clunk, not slip yoke as many people have said, and not "normal" driveline lash as dealers tries to say. Needle bearings were ground to dust and U-joint was holding up by a wing and a prayer, 50% worn on two sides.
I actually had success last year with mine just using a bench vise(the bigger the better though!) only having 5" to work with i barely made it with the aid ofa socket cut down to fit in there.Took me about 4hours because of the darn vise.
tjmicsak
Mar 21, 2012 05:48 PM
2oooBlazer
14
Jan 2, 2010 12:18 AM
88s10Blazer
Nov 29, 2006 02:56 AM
