How to pull ABS codes?
Old Oct 1, 2016 | 06:10 PM
tb30570's Avatar
tb30570 is on a distinguished road
Default How to pull ABS codes?
My ABS was kicking on a low speeds so I took out the sensors so I could remove corrosion build up under the sensor. One of them broke during removal so I drove around for a week with the ABS light on. I just replaced the broken sensor and the ABS light is still on. I checked the ABS fuse under the hood and it's fine.
Is there some way I can pull the ABS fault code so I at least know which wheel to look at?
Old Oct 1, 2016 | 10:28 PM
AJBert's Avatar
You need a scanner capable of pulling the ABS codes. They are pretty common these days and you might be able to go to a parts store and they'll be more than happy to pull the codes for you.
Blazers.B.Kewl
Apr 22, 2013 10:06 AM
KevT
Sep 8, 2012 02:05 PM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
