How to replace a thermostat
Old Oct 25, 2008 | 08:53 AM
sheps47's Avatar
sheps47 is an unknown quantity at this point
Default How to replace a thermostat
I have a 2001 Blazer ZR2 4x4 and need to know how to replace the thermostat on it. Any help would be appreciated! Thanks!
Old Oct 25, 2008 | 01:06 PM
rocksteady's Avatar
rocksteady is an unknown quantity at this point
Default RE: How to replace a thermostat
Easy as pie...assuming it is the same as my 96.....
All I had to do was take off the 2 bolts holding the housing down, lift the housing and hose out of the way...Ensure the block is clean, pop in the new one, tighten it up...Refill the fluids lost...Good to go....
Mine was stuck in there pretty good, so just used a long flat screwdriver to pop it out...
Ensure that the gasket on the thermostat is seated proper beofre you start bolting it down...Should not take more than about 15 minutes...
Old Oct 29, 2008 | 11:09 AM
sheps47's Avatar
Thanks! Should I try replacing the thermostat first and if that doesn't work, then try flushing the heater core?
Old Oct 29, 2008 | 02:54 PM
rriddle3's Avatar
What exactly are the symptoms you are trying to correct?
Old Oct 30, 2008 | 07:57 PM
sheps47's Avatar
Bought the blazer 2 months ago. When I test drove it the heat worked great. Now, it is getting cold here and no heat. It is not icy cold air coming out but it is lukewarm/chilly at best. Not sure why it is not warm all of a sudden and not sure what to try first. Have had some people tell me to replace thermostat, others say to flush the heater core. Any suggestions on what could be wrong would be greatly appreciated!
Thanks!
Old Oct 30, 2008 | 08:48 PM
rriddle3's Avatar
Why not do the thermostat andheater core flush together? Here's a good tutorial for the core flush. It might be wise to go ahead and change out the anti-freeze coolant completely if you don't know how old it is.
Old Nov 2, 2008 | 12:32 PM
sheps47's Avatar
Thanks for all the help and suggestions!! We flushed the heater core and it blows HOT now!
THANKS!!!!!!!!!!!!!!!!
jdcapri
Dec 11, 2011 12:21 PM
Weshard
Oct 28, 2005 01:26 PM
CKSMartin
Feb 24, 2005 02:39 PM
2001Blazer4x4
Engine & Internal
Feb 18, 2005 04:07 AM
2001Blazer4x4
Oct 31, 2004 01:13 PM
