Hub/Wheels heating up
Old Jun 10, 2012 | 11:37 PM
Little Roober's Avatar
Little Roober is on a distinguished road
Default Hub/Wheels heating up
Went to wash my truck yesterday and noticed that my front two wheels were getting pretty toasty after a short drive (more than usual). Could anyone tell me what would cause this? Both sides at going at once is kind of throwing me off.
Thanks,
Steve
Old Jun 11, 2012 | 12:06 AM
50lb_cat's Avatar
Did you recently do brake work? It could be your calipers sticking. Grease the caliper slide pins and the metal shims they travel on and see if that helps.
Old Jun 11, 2012 | 05:15 AM
Not for about a year, but I'll try it. Thanks.
Old Jun 11, 2012 | 03:06 PM
dobyken's Avatar
dobyken is on a distinguished road
It could either be sticky brakes or bad wheel bearings. I learned from experience that you will make a wheel bearing bad by not fixing the brakes promptly. Just a guess but the excess heat melts the permanent grease in the bearings which then also need replacing.
Old Jun 11, 2012 | 08:06 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
Mine was caused by bad brake line hoses.
Old Jun 11, 2012 | 09:36 PM
warthogdriver's Avatar
yeah...i will jump on the brakes bandwagon.
pads are hanging up for some reason.
lannon_j
Tires and Wheels
Apr 7, 2014 06:23 AM
95blazerlt
Tires and Wheels
Sep 25, 2013 08:48 AM
huntersblaze
Tires and Wheels
Jun 20, 2009 04:39 PM
98Blaz
Mar 24, 2005 01:32 AM
