Hum in front passenger wheel area
Old Oct 15, 2009 | 06:31 PM
southpaw's Avatar
southpaw is on a distinguished road
Default Hum in front passenger wheel area
I have a 99 Jimmy LS 4x4 with the 4.3 motor. The problem I am having is almost a rubbing noise that comes from my right front wheel well area. It tends to start after slowing down from highway speeds. I did discover that I can make it stop by puttingbit in 4hi and then back into 2hi. I can also make it start if I accelerate hard from under 30mph to above 50 and then ;etting off the gas. Once I change through 4hi back to 2hi, I can also tell there is less restriction on the truck. Any help would be appreciated.
Old Oct 15, 2009 | 06:35 PM
Sounds like the front axle engagement collar is hanging up. I would inspect the cable that runs from the actuator under the battery to the front axle for binding. Also, with the truck running and transfer case in 2HI, pull the vacuum line from the actuator. If there is vacuum at the actuator when in 2HI, the vacuum switch on the transfer case is bad.
Old Oct 15, 2009 | 08:35 PM
southpaw's Avatar
Is the info on where those are located in the Chilton? Just want make sure I can find what I'm looking for. I'm new to 4x4 and domestic. Was a tuner guy but I have been converted...
Old Oct 17, 2009 | 03:04 PM
814_fye's Avatar
814_fye is on a distinguished road
it sounds to me more like one of 3 things the axle tube bearing,cv axle or front hub it could also be in the brakes.
Old Oct 18, 2009 | 08:35 PM
deweasefan25's Avatar
deweasefan25 is on a distinguished road
is the 99 jimmy the same as a 99 ls blazer? If it is where is the vacuum line at to check? i have the same exact thing in my blazer. i see the cable but no vac line. thanks, Clint
Old Oct 19, 2009 | 02:15 AM
814_fye's Avatar
the vacuum line goes on from the bottom side of the vacuum actuator witch is probably under the battery box
Old Oct 19, 2009 | 05:17 PM
I have vacuum coming out of the line that I unhooked from the actuator. Am I correct to assume that the switch on the transfer case is bad? thanks, Clint
Old Oct 20, 2009 | 10:56 AM
814_fye's Avatar
it is more than likely the vacuum switch advance auto pats sell a Dorman help part# 49315 replacement swith for less than $20 I would give that a shot if that dont fix then it is more than likely the transfer case motor is failing and not locking back in 2 wheel drive.
Old Oct 20, 2009 | 07:30 PM
roycet4's Avatar
roycet4 is an unknown quantity at this point
Default I'm interested in this thread...
The front end on my '97 makes a humming too.. not too bad though until 60-70mph when it gets really loud in the passenger compartment. I've been thinking that its a wheel bearing.
Old Oct 21, 2009 | 05:01 AM
814_fye's Avatar
wheel bearings can normally be identified by test driving when noise accurs going around turns if it quits going to the left it is more than likely left wheel bearin and vise versa for the right if you jack it up and grab tire at 12 and 6 you might notice play in bearing but not always and if there is play make sure it's not ball joint play the humming could also be one of the inner cv axle joints or the front differential or 4x4 hanging up
lokiua4
Jul 8, 2011 11:17 AM
Machman1182
Jul 28, 2010 10:04 PM
rdhack
Apr 11, 2008 08:13 AM
seb226
Mar 16, 2008 05:58 PM
