98 Blazer - Noise in Passenger Front Tire area
Old Mar 16, 2008 | 05:27 PM
seb226's Avatar
seb226 is an unknown quantity at this point
Default 98 Blazer - Noise in Passenger Front Tire area
I have a 98 Blazer that has alight "woop woop" sound only really heard when slowing down from about 25 miles an hour. Two different reputable service stations could not diagnose the problem even though they heard the noise. I've had the front end completely repaired with Hub assemblies, bearings, pitman, idler arm, brakes, etc, and mechanically they find no problems with the front end. They also dismiss that the tires could be the issue. They suggest going to a chevy dealer shop who might have better diagnostic abilities. Any comments would be most welcome. (BTW, I just got finished having a new rebuilt engine installed due to major problems and aside from this noise, all seems perfect now.) thanks.
Old Mar 16, 2008 | 05:58 PM
Default RE: 98 Blazer - Noise in Passenger Front Tire area
This could be abnormal wear on the tires. If you have saw toothing of the tread, it can cause a cyclic noise like this. The old tires on my Rainier were saw toothed quite badly and it sounded like I had a bad wheel bearing on the front. New tires and the noise is now gone.
One thing to try if you suspect the tires is to rotate the front tires to the back. If that helps, then it is the tires.
er0ck273
48
Dec 15, 2014 04:17 PM
customwheels
Tires and Wheels
Jul 13, 2014 05:54 PM
bp2935
Tires and Wheels
Apr 21, 2011 06:37 PM
southpaw
Oct 21, 2009 05:01 AM
rdhack
Apr 11, 2008 08:13 AM
