HVAC fan question
So about a month ago my HVAC fan started cutting out intermittently, weather it was on heat or AC. Now it won't come on at all. I had the fan replaced last year, so my question is before going out and getting a new fan is there anything else I should check? All my fuses are good. TIA.
Not meaning to hijack your thread, but have you found a resolution?
I posted a similar problem about 2 weeks ago, but did not get a response. I have a 98, with Automatic Climate Control. I started blowing erratically, on/off - high/low, and then quit. Every once in a while, it will come on, but normally, nothing. I have replaced the blower (fan), the controller (on the dash), and the fan control under the hood (near the blower). All fuses, and relays have checked out, and after searching the forum, I checked voltages at some points that were indicated for other (similar) problems.
Does anyone have any ideas???
![Smile](https://blazerforum.com/forum/images/icons/icon7.gif)
The fan switch on the dash is the switch I'm referring to. Is this an automatic climate control? If so I have no idea. Sorry
The blower motor resistor is located on top of the HVAC housing under the hood. You may have to cut some of the plastic outer shroud off to access it.
If your fan only works on high, then I would definitely take a look at the resistor. Somewhere around here I posted what the resistances should be throughout the resistor...
jolech550
05-17-2013 07:35 AM
cheesequaker
04-25-2012 01:44 PM
valeria1782
01-24-2011 04:12 AM
