hvac issues
Old Mar 25, 2010 | 12:16 AM
larryou812's Avatar
larryou812 is an unknown quantity at this point
Unhappy hvac issues
i have a 2003 s10 blazer 4x4 with manual hvac controls. im having trouble with air only blowing out the dash vents regardless of dial position.i found the vacuum chart but im not able to find the logic chart.any help would be appreaciated.thanks
Old Mar 26, 2010 | 08:45 AM
larryou812's Avatar
i started replacing vacuum lines and i can now get air were it is supose to be.but under hard acceleration i seem to be loosing vacuum because air starts blowing out dash vents again.when i let off the gas air slowly returns to normal.i was wondering if the a bad check valve in the vacuum line could be causing this and also how long should the system hold vacuum when the motor is turned off?THANKS for any help
kbar25
Sep 18, 2011 08:59 AM
Vahomboy
Dec 29, 2010 07:22 AM
daturbosix
Oct 20, 2010 09:28 PM
ncc74656m
Jun 18, 2010 10:43 PM
Clay_Assassin
Mar 18, 2008 09:36 AM
