HVAC problems
Old Feb 6, 2011 | 03:19 AM
Longer02's Avatar
Longer02 is an unknown quantity at this point
Default HVAC problems
Installed some Hella 500's tonight on a bull bar. Everything works as planned however, the HVAC controls only allow air to flow out of the main vents in the dash now. I ran the light wire through the driver side firewall if that matters at all. Also, took out most of the dash to mount the switch. What could have caused this issue? Everything worked somewhat normal before.
Also, I have the computer climate control. I have noticed that moving the temp gauge to a lower temp caused it to blow cold air no matter what the setting. Any ideas? Thanks.
Old Feb 7, 2011 | 09:31 AM
RonJon's Avatar
RonJon is an unknown quantity at this point
Check all your vacuum lines for one knocked off.
Old Feb 7, 2011 | 01:46 PM
Longer02's Avatar
Yeah I suspected that as well. Gave the engine bay a quick look over yesterday and didn't see anything out of the ordinary. Will have to poke around and check all the lines when I have some more time.
Old Feb 8, 2011 | 04:50 AM
DaveHearne's Avatar
DaveHearne is on a distinguished road
I'm with RonJon on this one - you almost certainly have a vacuum line that is disconnected somewhere. Before you take the dash apart again, follow the HVAC vacuum line that runs through the firewall back & see if it's disconnected in the engine bay. It will save a lot of unnecessary work if that were to be the case. One of my lines came off where it goes into the little vacuum reservoir behind the fender - it caused all sorts of weird things to happen to the HVAC system as well as affecting the 4wd operation too.
Old Feb 8, 2011 | 07:10 AM
Longer02's Avatar
The strange thing is my 4wd still functions properly. I figured that the HVAC problems would have caused the 4wd to not work too. I am going to check the lines tonight though and see what I can find. Thanks guys.
bassson
Jun 26, 2018 07:09 AM
mikes95blzr
Jan 22, 2013 09:31 PM
gtdownonit
Jun 21, 2011 01:24 AM
chervyfun21
Feb 9, 2010 10:30 AM
upblazer95
Apr 4, 2009 08:27 PM
