i cant get the shifter to change gears
Old Dec 25, 2011 | 11:08 AM
Rhett McNair's Avatar
Rhett McNair is on a distinguished road
Default i cant get the shifter to change gears
I just replaced my heater core and bolted everything back together and was about to go drive it and I can't get it to change gears at all. Any suggestions?
Old Dec 26, 2011 | 04:49 AM
step66's Avatar
column shift or floor shift? either way you overlooked something on reassembly!good luck!
Old Dec 26, 2011 | 05:41 AM
dman001948's Avatar
dman001948 is an unknown quantity at this point
Stick shift or Auto? If its a stick, check your trans fuild, could be very low or bad grears. On a Auto, You replace your heater cord right? I don't see how that ties in with the trans what so ever. Could be wrong...just don't how it could. Need more info.
Old Dec 27, 2011 | 06:36 AM
Column shift, I found it already, it was a little cable on top of the column was broken.
matthewp
Apr 4, 2021 09:16 PM
James1965
Jan 16, 2012 11:32 AM
jasedude
Nov 24, 2010 04:03 PM
gumpy69
Nov 4, 2010 07:57 PM
rbcar1
Dec 13, 2009 10:20 AM
