I have no noid to check the injector pulse.
Old Sep 7, 2011 | 05:16 PM
Chevy33's Avatar
Chevy33 is on a distinguished road
Default I have no noid to check the injector pulse.
Can I use a test light to check for pulse on the connector for the fuel injection? 1999 4.3 Cranks but no start.
Old Sep 7, 2011 | 05:30 PM
A regular incandescent bulb can take too long to illuminate given a typical injector pulse, measured in milliseconds. LED's are best, but with LEDs, you have to be mindful of polarity (+ & - side of the LED connected appropriately to the injector wires).
It is quite rare to have an actual electronic injector problem with these trucks. What is much more common is fuel pressure issues. Check out the Tech Article (DIY) link found in my signature below and look for the no-start ignition system tests as well as the fuel pressure diagnosis thread.
Old Sep 7, 2011 | 06:49 PM
Tobashadow's Avatar
Tobashadow is on a distinguished road
A $2 mechanics stethoscope will tell you.
You can compare the noise it makes when you touch the rod against the injector body's.
You can hear the clicks from it spraying really easy, it's not perfect but can rule out alot quickly.
Old Sep 7, 2011 | 07:22 PM
Mike98Blazer's Avatar
Problem with that theory is that the CPFI on these vehicles is squeezed between the upper and lower intake. And if it's older than 2003 IIRC it has poppet valves on the ends instead of electronic injectors.
Old Sep 7, 2011 | 08:06 PM
Tobashadow's Avatar
Forgot about the chicken crap CPFI systems. But on standard per cylinder motors or tbi that works perfectly.
Old Sep 7, 2011 | 08:07 PM
Yes sir it does. Just one more thing that is slightly more difficult about the 4.3 than it needs to be lol
fishinkings
Mar 16, 2013 06:56 AM
nate_v8
Jun 17, 2011 11:47 AM
cwh94
Oct 22, 2009 08:35 AM
bbr
Aug 6, 2009 07:45 PM
br1amb
Mar 28, 2008 08:58 AM
