i have two problems
Old Feb 19, 2007 | 04:23 AM
20Blazer00's Avatar
Default RE: i have two problems
If all the vacuum lines are good?? Then you could have a sticky poppet valve or leaking fuel pressure regulator, the excees gas getting into the intake makes it difficult for the computer to adjust the injectors and so it sees the truck running rich only on certain cylinders and then tries to adjust the A/F ratio from the O2sensor readings and things get mixed up causing a misfire code in the computer and rough idle...
Get the computer scanned for DTC's, if there are any then you will get closer than guessing to possibilities.
jlg822
Aug 13, 2011 02:21 PM
The_Beast
Mar 27, 2010 06:32 PM
CNYCountryKidd
Dec 6, 2009 05:00 PM
whitezombie198
Jan 18, 2009 12:58 AM
drefda
Dec 14, 2006 01:37 PM
