I need alot of help.
I purchased a 1998 S-10 2dr Blazer. It is the 4x4 v6 4.3L
I purchased it in 2002 with 37k on it.
It now has 66k on it.
Besides regular oil and air filter changes I have
In 2003
Replaced belt
New tires
New front and rear rotors and pads
In 2004
Replaced thermostat
New Water Pump
Flushed radiator
Replaced fuel filter
In 2005
Replaced belt tensioner
New Master Cylinder
front bearings
Replaced rear calipers and rotors (caliper spring broke, thus destryoing the 2 year old rotors)
Cleaned all carbon off of throttle body.
I was wondering if there was any aftermarket throttlebodies that would allow for more airflow? I don't want to spend $250 for a F&N cold air kit either.
I am also having problems shifting into 4 WD so I will try to replace the vacuum switch. I need the part number or an image or link to an online retailer that sells it. The people at Napa quoted me $36 but I thought it was around $50 so I want to make sure they are quoting me the correct piece.
I was wondering what else I should be getting ready to do? Plugs, wires, distributor? The front calipers are looking horrible. How hard are they to change yourself? The Haynes manual has been alot of help in guiding me through most of what I have done, but I am hesitant to work on the brakes. The front wheel is also making a skreaching noise when I drive under 10mph. I clean the rotors and the noise goes away for a few days then returns. The pads are only 2 years old so would they wear out this quickly?
I am also having the infamous wiper problem. I plan on resoldering the circuit board this weekend.
Any suggestions on what else I should be looking to do?
In 2003
Replaced belt
New tires
In 2004
Replaced thermostat
New Water Pump
Flushed radiator
In 2005
New Master Cylinder
front bearings
plugs wires like you said maybe a fuel filter change if that hasnt been done in a while, maybe a chasis lube? ..... as for the brakes i cant help you with that im in the same boat as far as workin on them myself... sorry dude
I would be lookin to replace plugs, wires, distributor cap, and ignition rotor.
Front brake pads don't last long on my truck for the same reason they don't on Dobbist's, lol.
ORIGINAL: dobbist
well for brakes i usualy replace them every year but i also have to slam on the brakes a lot, i tell ya women should not be allowed to drive
You haven't experienced frustration till you've driven behind my mom. She drives like a drunk, lol. She'll speed up, then slow back down, speed up, and slow back down again. I almost totalled my Mustang one day cuz I was followin her and got pissed off. I slung it down into 4th and slung around her...and there was a car coming. Ironically it was a Blazer, hehe.
But yeah, I'm gonna have to stick with Dobbist on this one. I've had to slam on brakes for women way more than I have men
uh-oh, i see a fight brewing up here. i think youre a little out numbered moonwater. i have to take a new side here...old people are the worst drivers. they're the ones who drive into malls and into the middle of parades and run people over. plus they ride their brakes, so you never know when they're really going to stop. [sm=shootshoot.gif]
Well, I just put in a new PCV valve.
I took out the wiper circuit board and resoldered the cracked pins. Hopefully that will solve my ghost wiper problem.
Tomorrow I replace the vacuum switch.
Then the only thing left is the calipers.
The aftermarket throttle bodies are WAAAY more expensive than a CAI. Also, as for your 4x4 problem, have the car PC checked. Blazers have a problem with the program for the 4x4 (98+ blazers and s10's) It just needs to be reprogrammed. I just had it done a few months ago
