I Need Serious Help Here!!!!!!
Old Jul 13, 2009 | 08:33 PM
chrisjanicki01's Avatar
chrisjanicki01 is an unknown quantity at this point
Angry I Need Serious Help Here!!!!!!
2000 Chevy Blazer
4.3L V6 Vortec
Single Rear Exit DynoMax exhaust
3 1/2 Down Pipe
Problems:
Fuel Gauge Fluxuation - Voltometer fluxuation - ABS kicks on when taking right turns(no matter the condition) - weird grinding Noise upon Acceleration - today my battery died. i got a jump. on my eway home after jump, everytime i hit the break, the lights would flicker and the radio resets - while getting a jump, my rear window kept opening - quick burning oil - HELP MY PLEASE
Old Jul 13, 2009 | 09:55 PM
First off, check your battery cables and then have your charging system analyzed.
It sounds like you have a number of problems. The electrical system, being the heart of your vehicle, would be the first one I would address.
Old Jul 13, 2009 | 11:55 PM
1995 Blazer's Avatar
1995 Blazer is on a distinguished road
sounds like u need a new blazer. kinda like my truck but i keep fixing it good luck
Old Jul 14, 2009 | 04:23 PM
martyde's Avatar
martyde is on a distinguished road
Default I need some serious help
As far as the elctrical problem is concerned, it could be as simple as the ground wire from the engine making intermitent connections. A loose or failed ground between the engine and the frame can cause havoc with the electrical systems not to mention charging problems.
You need to check your battery voltage at around 2000 RPM with the headlights and AC running on HI. It should be nearly 14.2 VDC. If not you may have a lazy alternator. You can ckeck the ground issue by performing a continuity check with an OHM meter from teh negitive terminal of the battery and the "frame". be sure both points of connection are clean. You chould read one (1) OHM or less.
Md
Old Jul 14, 2009 | 05:26 PM
amazinnblazin's Avatar
amazinnblazin is an unknown quantity at this point
sorry the only thing I can do is pray for your truck!
Old Jul 14, 2009 | 08:11 PM
bandidolenny's Avatar
Sounds like you have some ground issues... I would start by replacing both battery cables just for the hell of it. After that start checking (or run new) the grounds from the batt to the body and body to engine... don't forget about the computer ground as well.
Your ABS may be something to do with the wire harness near where it goes into the front wheel sensor... check to make sure it hasn't rubbed a hole in the wires there when turning.
Doverman454
Aug 14, 2010 11:46 PM
jstein
Tires and Wheels
Aug 20, 2009 07:32 AM
gary_gautney23
Jul 13, 2009 08:09 PM
lionel2
31
Mar 14, 2008 09:58 PM
bowanna03
Oct 1, 2006 03:10 PM
