I need some help
I need some help
hello, i have a 1997 blazer 4x4. The problem is that while crusing at low to moderate speed, the speedo drops to zero, the abs light comes on and the tranny locks into second gear. this is an interrmitant problem, and i have no clue whats causing this, i thought maybe a bad vss or exciter ring, if anyone else has had this problem it would be greatly appreciated for any advice. i have been told that my ignition switch could be bad? I thought that if that were the case, all my instrument panel would gor dead, but only the speedo goes dead.
thanks matt
thanks matt
RE: I need some help
Hello,
Does your cruise control work?
Josh <><
Josh <><
I'm thinking that the VSS is your problem. From AllDataDIY.com:
Advanced Autoparts shows 3 different VSS, one of them is for the 5spd. The other two (~$43 & ~$30) would need to be matched up with your current sensor to ensure compatibility.
These newer electronically controlled transmissions are very sensitive when it comes to readings from sensors. It is quite possible that your sensor has gotten dirty and just needs to be cleaned. I would try this first before dropping $$$ into buying a new sensor.
For reference, the sensors are:
GP Sorensen 7799517 - Speed Sensor - $42.96
GP Sorensen 7799588 - Speed Sensor - $29.88
I'm sure that one is for the 4wd and the other for the 2wd, but Advanced Auto's website does not differentiate between the two. I'm sure your local store can help you out with that determination.
The Vehicle Speed Sensor (VSS) is a pulse counter type input that informs the VCM how fast the vehicle is being driven. The VSS system uses an inductive sensor mounted in the tail housing of the transmission and a toothed reluctor wheel on the tail shaft. As the reluctor rotates, the teeth alternately interfere with the magnetic field of the sensor creating an induced voltage pulse.
The VSS produces an AC voltage signal that increases with the vehicle speed. The VCM processes this signal and sends it to the following components:
* The instrument panel
* The cruise control module
Hey guys thanks for the help, just today it posted a dtc for the vss i replaced it and no problems yet. Thanks again guys
davidluzader
03-01-2010 10:25 AM
rcravincase
09-13-2009 07:58 PM
ZLover4Life
46
12-22-2008 01:01 AM
scottyk
03-19-2007 11:32 PM
