IAC valve cleaning how-to
Old 06-07-2009, 09:18 PM
JHZR2's Avatar
JHZR2 is on a distinguished road
Default IAC valve cleaning how-to
Hello,
I have a 98, and would like to clean the IAC. I found the EGR cleanup how-to, but nothing on the IAC.
Where do I find this item? Ive seached enough to see how to do it for the most part, my key is knowing where it is.
Thanks!
Old 06-07-2009, 10:40 PM
ABN31B's Avatar
Idle Air Control Valve.... hmm... check on the side of your throttle body. From a quick google image search most are in generally the same spot. Couldn't find one on a Blazer, but heres a Camaro, so same car company...
Click Me
Old 06-08-2009, 06:57 AM
JHZR2's Avatar
Oh, OK. Thanks. It seemed that they were all more or less the same,but it was tough to tell. Ill do some digging this weekend - I know Ive never cleaned it before!
Thanks,
JMH
Old 06-08-2009, 09:50 PM
The image posted above shows an almost (if not) identical IAC valve. It is located on the driver side, rear of the throttle body pointing towards the passenger side.
Old 06-09-2009, 12:59 AM
ABN31B's Avatar
*flex* What can I say... I'm just that good.
Old 03-26-2010, 07:55 PM
torchred04's Avatar
torchred04 is on a distinguished road
What type of cleaning solvent are you guys using?
Old 03-26-2010, 08:04 PM
I use CRC sensor safe throttle body cleaner.
Old 05-23-2012, 08:40 PM
WayneMurray1's Avatar
WayneMurray1 is on a distinguished road
Awesome post, I had the exact same questions! Thanks jhzr2 and you 2 guys that answered!!!
Old 05-23-2012, 08:45 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
just get a can of brake cleaner and your wifes toothbrush. remove iac,scrub and clean it with cleaner,reinstall and smile.
Old 05-23-2012, 11:54 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Would the spray type seafoam work? or is that not sensor safe? i just threw my bottle away so i cant check.
And that spray seafoam is amazing. i used it to clean the TB and it turned the heavy carbon into soup.
Quick Reply: IAC valve cleaning how-to
